*feoutputwithdata - HM_REAL_VALUES_E_OPTION
Custom export options are written to the command file as a string array, associated with the *feoutputwithdata command.
Custom export options are written to the command file as a string array, associated with the *feoutputwithdata command. The easiest way to produce this array is to output an FE file using the desired parameters, and then to examine the string array in the resulting command file.
- "HM_REAL_VALUES_E_OPTION"
 - When used in conjunction with the template command *compressreal (with flag set to 3), this provides for a way to override the default behavior of outputting real numbers without an ‘E’, where applicable.
