*feoutputwithdata - HMCOMMENTS_SKIP
Custom export options are written to the command file as a string array, associated with the *feoutputwithdata command.
Custom export options are written to the command file as a string array, associated with the *feoutputwithdata command. The easiest way to produce this array is to output an FE file using the desired parameters, and then to examine the string array in the resulting command file.
- "HMCOMMENTS_SKIP"
 - When used in conjunction with the template function @writehmcomments, this provides a way to prevent HyperMesh comments from being written to the output file.
