Modules
Modules behavior for *setvalue.
*setvalue for Representations
*setvalue modules <select_type>=<selection> rep_action=<action> ?rep_name=<name>? ?rep_type=<type>? ?rep_filename=<filename>? ?rep_filecategory=<category>? ?rep_fileformat=<format>? ?detail_name=<name>? ?detail_value=<value>? ?detail_type=<type>?
- rep_action=<action>
 - add - Add a representation. rep_name and rep_type are required, and rep_filecategory is optional.
 - rep_name=<name>
 - The name of the representation.
 - rep_type=<type>
 - The type of the representation.
 - rep_filename=<type>
 - The name of the representation file.
 - rep_fileformat=<type>
 - The format of the representation file.
 - rep_filecategory=<type>
 - The category of the representation file.
 - detail_name=<name>
 - The name of the detail when rep_action is detailremove or detailset.
 - detail_value=<value>
 - The value of the detail when rep_action is detailset. Its type must match detail_type, if specified.
 - detail_type=<type>
 - The type of the detail when rep_action is detailset.
*setvalue for Modules
*setvalue modules <select_type>=<selection> detail_action=<action> detail_name=<name> ?detail_value=<value>? ?detail_type=<type>?
- detail_action=<action>
 - set - Adds/modifies a detail. detail_name, detail_value and detail_type are required.
 - The name of the detail the detail_action is performed on.
 - The value of the detail when detail_action is set. Its type must match detail_type, if specified.
 - The type of the detail when detail_action is set.
Representation Option Information
Both the name and type are required to define a representation uniquely. The UDM ID can be used, but it is not always available. So in every command that handles a representation both rep_name and rep_type are required.
- CAD
 - Conn
 - Mesh
The file category (rep_filecategory) must have the same value as the representation type (rep_type). However, some use cases may set this to OnImport. Again, there is no locking to any specific values, and the command does not check for the validity of this parameter.
- rep_type is CAD
- ACIS
 - CATIA
 - CATIA V4
 - CATIA V5
 - CATIA V6
 - DXF
 - HMAscii
 - HyperForm
 - HyperMesh
 - IGES
 - JT
 - Parasolid
 - PDGS
 - Creo
 - SolidWorks
 - STEP
 - STL
 - Unigraphics
 - VDAFS
 - rep_type is Conn
- Connector
 - Weld
 - rep_type is Mesh
- Abaqus
 - Actran
 - ANSYS
 - Ansa
 - HMAscii
 - HyperForm
 - HyperMesh
 - LS-DYNA
 - MADYMO
 - Moldflow
 - Nastran
 - OptiStruct
 - PAM-CRASH
 - PAM-CRASH 2G
 - Permas
 - Radioss Block
 - Radioss Bulk
 - Stl
Examples
*setvalue modules id=4 rep_action=add rep_name="MyRep" rep_type="Cad"*setvalue modules id=4 rep_action=addfile rep_name="MyRep" rep_type="Cad" rep_filename="C:/MyFiles/rep13.jt" rep_fileformat="JT"*setvalue modules id=4 rep_action=detailset rep_name="MyRep" rep_type="Cad"
      detail_name="Identity" detail_value="AK123" detail_type=string*setvalue modules id=4 rep_action=detailset rep_name="MyRep" rep_type="Cad"
      detail_name="Identity_Type" detail_value="34" detail_type=int*setvalue modules id=4 detail_action=set detail_name="Revision"
    detail_value="13.2.54-7.6.2"*setvalue modules id=4 detail_action=remove detail_name="Revision"Version History
2017
