Notes and Limitations
There are several issues, limitations and special behaviors of *setvalue that are important to know.
When updating a string value, if there are any continuous spaces, the Tcl interpreter truncates these extra spaces. To prevent the truncation, specify the value to be updated as a separate string, or enter a space after the =.
*setvalue mats id=1 name={This is          name}*setvalue mats id=1 name= {This is          name}set name "This is          name"
*setvalue mats id=1 name=$name*createentity sets type=element name=test ids=[hm_getmark elems 1]eval *createentity sets type=element name=test ids=[ list $elems ]eval *createentity sets type=element name=test ids={ [hm_getmark elems 1] }eval *createentity sets type=element name=test ids={ $elems }Data names for beamsections, geometry entities, and morphing entities are not supported.
- ddvals
 - rangeindex
 - dequations
 - number_of_lines
 - designvars
 - anchorpoint
 - desvarlinks
 - coeff
 - dobjref
 - objectid
 - dvprels
 - coeff
 - opticontrols
 - minmeth
 - optiresponses
 - coordinate_type_list
- equations
 - independentcoeffs
 - laminates
 - interfacepairplyids
 - plies
 - entitylist
 - plots
 - curves
 - tables
 - marked_columnlabel
Update on row=<row_index> does not work for 1D entity attributes, and update on both row=<row_index> and column=<column_index> are not supported for all types of 2D attributes.
